*hf_createdoubleattachedparams
Creates the base point for the symmetry plane, the n1/n2 node of the given line and the part of this line between n1/n2 needed for the double attached feature.
*hf_createdoubleattachedparams line_mark nodes_mark gap x_sym y_sym z_sym x_draw y_draw z_draw creation_flag
HyperMesh Tcl Modify Command
This command creates the base point for the symmetry plane, the n1/n2 node of the given line and the part of this line between n1/n2 needed for the double attached feature.
- line_mark
 - The mark ID containing the single input line. Valid values are 1 and 2.
 - nodes_mark
 - The mark ID containing the input nodes. Valid values are 1 and 2. The node mark must contain 0, 1 or 2 nodes. If it contains 0 or 1 node it will create n1/n2 from line. If it contains 2 nodes it will try to use them, but if they are not properly chosen, it will create n1/n2 from line.
 - gap
 - The minimum distance between the original and reflected part.
 - x_sym
 - The x-coordinate of the symmetry direction.
 - y_sym
 - The y-coordinate of the symmetry direction.
 - z_sym
 - The z-coordinate of the symmetry direction.
 - x_draw
 - The x-coordinate of the stamping direction.
 - y_draw
 - The y-coordinate of the stamping direction.
 - z_draw
 - The z-coordinate of the stamping direction.
 - creation_flag
 - 0 - Create base point.
*createmark lines 1 1
*createmark nodes 1 100 101
*hf_createdoubleattachedparams 1 1 0.5 1 0 0 0 1 0 0Errors
   # Handle error
}Version History
12.0
