*sketchproject
Projects line and surface entities into the sketch work plane along the normal direction.
*sketchproject sketch_id entity_type mark_id ?create_entities? ?only_displayed?
HyperMesh Tcl Modify Command
Projects the line and surface entities into the sketch work plane along the normal direction.
- sketch_id
 - The ID of the sketch entity.
 - entity_type
 - The type of selected entities. Valid values are lines, points, surfaces, topolines, and topopoints.
 - mark_id
 - The ID of the mark containing the entities. Valid values are 1 and 2.
 - create_entities
 - 0 - Projected curves are added as guide curves in the sketch.
 - only_displayed
 - 0 - All entities in the input mark are considered.
Examples
*createmark surfaces 1 8
*sketchproject 1 surfaces 1 1Errors
   # Handle error
}Version History
2021.2
