*realizeentity
Realizes an engineering entity into solver data.
*realizeentity entity_type <select_type>=<selection> ?option1=<value1> option2=<value2> ...?
HyperMesh Tcl Modify Command
- entity_type
 - The type of engineering entity to realize. Currently only supported for fields.
 - <select_type>=<selection>
 - The engineering entity to realize. There are several ways to provide the entity to be
            modified. Only one option can be used at a time:
- id=<id>
 - The ID of the single entity to modify.
 - name=<name>
 - The name of the single entity to modify.
Examples are provided within the subtopics of each supported entity type.
   # Handle error
}Version History
14.0
