*createjointelement_twonoded
Creates a two-noded joint element.
*createjointelement_twonoded type node1 node2 orientation o_node1 o_node2 o_system1 o_system2 property
HyperMesh Tcl Modify Command
- type
 - Element type to create. Valid values are 1 and 25 through 33.
 - node1
 - The ID of the first node.
 - node2
 - The ID of the second node.
 - orientation
 - A flag indicating how the orientation of the element is defined. Valid values are:
- 0 - None.
 - 1 - Systems.
 - 2 - Nodes.
 - o_node1
 - The ID of the first orientation node. Ignore, if orientation is not 2.
 - o_node2
 - The ID of the second orientation node. Ignore, if orientation is not 1.
 - o_system1
 - The ID of the first orientation system. Ignore, if orientation is not 2.
 - o_system2
 - The ID of the second orientation system. Ignore, if orientation is not 1.
 - property
 - The ID of the property to assign to the element.
Examples
*createjointelement_twonoded 25 62 2 1 0 0 454 465 ""Errors
   # Handle error
