*translatemarkwithsystem
Translates a selection of entities along a vector of the specified system.
*translatemarkwithsystem entity_type mark_id vector_id distance system_id origin
HyperMesh Tcl Modify Command
This command translates a selection of entities along a vector of the specified system.
- entity_type
 - The type of entity to translate.
 - mark_id
 - The ID of the mark containing the entities. Valid values are 1 and 2.
 - vector_id
 - The ID of the vector to use for the translation. This is defined using the *createvector command. The vector is relative to the specified system.
 - distance
 - The distance to translate.
 - system_id
 - The ID of the system which the vector is relative to. Note that the type of system affects the meaning of vector. For example, the vector (1, 0, 0), x-axis, in a cylindrical coordinate system translates the mark radially out from the origin.
 - origin
 - If zero, the vector is based at the origin of the system. Otherwise, it specifies a node ID whose coordinates define the base point of the vector.
*createvector 1 0.0 1.0 0.0
*createmark nodes 1 1
*translatemarkwithsystem nodes 1 1 5.0 13 2Errors
   # Handle error
