*flanges_detect
Finds and selects flanges from specified geometry.
*flanges_detect comp_mark_id max_width min_width flage_mark_id
HyperMesh Tcl Modify Command
This command detects flanges within a minimum/maximum width range from the surfaces contained in the selected components. The flange surfaces are then placed on a mark.
- comp_mark_id
 - The mark of input components. Valid values are 1 and 2..
 - max_width
 - The maximum width of the flanges to detect.
 - min_width
 - The minimum width of the flanges to detect.
 - flange_mark_id
 - The mark of the output surfaces defining the detected flanges. Valid values are 1 and 2.
*createmark comps 1 all
*flanges_detect 1 5 20 2Errors
   # Handle error
