*hf_Addendum_PrepareLatitudeLine
Finds the latitude lines to drag and organize them into the component ^latitude_lines_drag.
*hf_Addendum_PrepareLatitudeLine int_flag
HyperMesh Tcl Modify Command
This command finds all of the model’s latitude lines to drag and organize them into the ^latitude_lines_drag component.
int_flag
Dummy integer value. Should always be set to 0.
To see all the model’s latitude lines that you can drag:
*hf_Addendum_PrepareLatitudeLine 0
   # Handle error
