*hf_TranslateBinderSurf
Translate the binder along an axis in space. The binder is automatically identified.
*hf_TranslateBinderSurf plane distance
HyperMesh Tcl Modify Command
This command translates the binder along an axis. The direction of translation is given by the plane/vector plane and the magnitude of translation is given by distance.
plane
The temporary plane/vector ID created using the *createplane command.
distance
Translation distance.
Examples
To translate the binder along the z-axis with magnitude 50:
*createplane 1 0.0000 0.0000 1.0000 0.0000 0.0000 0.0000
*hf_TranslateBinderSurf 1 50
To translate the binder along the x-axis with magnitude -50:
*createplane 1 1.0000 0.0000 0.0000 0.0000 0.0000 0.0000
*hf_TranslateBinderSurf 1 -50
   # Handle error
Version History
10.0
