*minmaxtitlemove
Moves a minimum or maximum title.
*minmaxtitlemove xmin ymin xmax ymax type minmax
HyperMesh Tcl Modify Command
xmin
The x value of the upper left corner of the title (0.0 - 1.0).
ymin
The y value of the upper left corner of the title (0.0 - 1.0).
xmax
The x value of the lower right corner of the title (0.0 - 1.0).
ymax
The y value of the lower right corner of the title (0.0 - 1.0).
type
0 - Node title (contour plot)
1 - Element title (assigned plot)
minmax
0 - Minimum title
1 - Maximum title
None.
