*elementqualitycollapseedge
Collapses an edge between two elements.
*elementqualitycollapseedge elem_id edge_index
HyperMesh Tcl Modify Command
This command collapses an edge between two elements.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
- elem_id
 - The element ID.
 - edge_index
 - The index of the edge to collapse.
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualitycollapseedge 20 1
*elementqualityshutdown 1Errors
   # Handle error
}Version History
13.0
