*elementqualitysmoothnodesnew
Smooths/optimizes nodes of selected elements.
*elementqualitysmoothnodesnew elem_mark_id nodes_mark_id algorithm target_qi max_iterations time_limit
HyperMesh Tcl Modify Command
This command smooths/optimizes nodes of selected elements.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
Current element quality criteria for optimization must be set before using this command. The command may be applied at any time without resetting the current quality criteria.
- elem_mark_id
 - The mark ID containing the elements to smooth. Valid values are 1 and 2.
 - node_mark_id
 - The mark ID containing any anchor nodes. Valid values are 1 and 2.
 - algorithm
 - 0 - Autodecide.
 - target_qi
 - The target QI value, when algorithm is set to 3.
 - max_iterations
 - The maximum number of iterations, when algorithm is set to 3.
 - time_limit
 - The maximum time limit, when algorithm is set to 3.
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*createmark elems 1 1-100
*elementqualitysmoothnodesnew 1 1 3 0.2 5 0
*elementqualityshutdown 1Errors
   # Handle error
}Version History
13.0
