*CE_ConnectorAreaMapMesh
Use the projections of components or elements to mesh area connectors.
*CE_ConnectorAreaMapMesh ce_mark entitytype entitymark vectorptr tolerance param1
HyperMesh Tcl Modify Command
- ce_mark
 - The mark containing the area connectors..
 - entitytype
 - The type of entities to map from.
 - entitymark
 - The mark containing the comps or elems to map from.
 - vectorptr
 - The direction to project.
 - tolerance
 - The allowable distance from the comps/elems to the area connectors.
 - param1
 - For future use.
Examples
*createmark(connectors, 1) 1, 2, 3
*createmark(elems, 1)4, 5, 6, 7, 8
*createvector(1, 0.0, 1.0, 0.0)
*CE_ConnectorAreaMapMesh(1, elems, 1, 1, 10.0, 0)Meshed area connector displays as a plane with virtual elements.
