*EntityMoveUsingArray
Organize a different group of elements to their respective collectors.
*EntityMoveUsingArray entity_col IdSizeArray numRows numCols ent_to_move entityIds numEnts
HyperMesh Tcl Modify Command
- entity_col
 - Entity collector type that holds the entity IDs.
 - IdSizeArray
 - A 2D array that contains the collector IDs specified by the entity_col variable and a size value that specifies the number of entities that need to be moved from the entityIds array.
 - numRows
 - The number of rows for the 2D array.
 - numCols
 - The number of columns for the 2D array. This MUST always have a value of 2.
 - ent_to_move
 - The entity type to be organized in the collector.
 - entityIds
 - Array of specific entity type IDs to be organized into specific collectors.
 - numEnts
 - The size of the entity ID array.
This command currently supports moving elements to components only. This is optimized for organizing a different group of elements to their respective collectors from a Tcl script. For example, elements with IDs 1 to 5 must be moved to component ID 1, elements with IDs 6 to 10 must be moved to comp ID 2 and elements with IDs 11 to 15 must be moved to comp ID 3.
*createentityarray2d 3 2 1 5 2 5 3 5;*createarray 15 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15;*EntityMoveUsingArray COMPS 1 3 2 ELEMS 1 15;
