*attributeupdatestringarraymark
Updates an attribute of type string array on a set of entities.
*attributeupdatestringarraymark entity type mark identifier solver status behavior data length
HyperMesh Tcl Modify Command
- entity type
 - The type of entity that owns the attribute.
 - mark
 - The number of the mark.
 - identifier
 - The identifier of the attribute.
 - solver
 - The solver number of the attribute.
 - status
 - The status of the attribute.
 - behavior
 - The behavior of the attribute.
 - data
 - The string array.
 - length
 - The string array length.
Examples
*createmark(materials,1) 7 8
*createstringarray(2) "layer1" "layer2"
*attributeupdatestringarraymark(materials,1,615,2,2,0,1,2)
