*feinputinteractive
Inputs an ASCII analysis input deck, and for certain import translators, invokes a Part Browser to allow selecting various options while importing the chosen model.
*feinputinteractive programname filename overwrite min_edge_length cleanup_tolerance blanked_component offsetflag
HyperMesh Tcl Modify Command
Inputs an ASCII analysis input deck and for certain import translators invokes a Part Browser to allow selecting various options while importing the chosen model.
programname
The name of the translator program.
filename
The file name containing an input deck.
overwrite
  • 1 - If HyperMesh should overwrite any existing IDs,
  • 0 - If HyperMesh should offset.
min_edge_length
Not used.
cleanup_tolerance
  • If < 0, use automatic cleanup tolerance.
  • If = 0, do not cleanup topology.
  • If > 0, use this as cleanup tolerance.
blanked_component
  • 1 - Create an empty component for data.
  • 0 - Do not create an empty component.
offsetflag
Apply a user-defined offset.
To read the Abaqus input file named model:
*feinputinteractive "feinput/abaqus" "model" 0 0 -0.01 10.0 0
