*section_plane_mesh
Generates a shell mesh from a selection of planar boundary elements.
*section_plane_mesh entity_type mark_id mesh_type elem_size connectivity elem_mark_id tol
HyperMesh Tcl Modify Command
- entity_type
 - The type of entity to use as input for the boundary. Valid values are comps and elems.
 - mark_id
 - The ID of the mark containing the input entities. Valid values are 1 and 2.
 - mesh_type
 - Flag indicating the type of mesh to generate. Valid values are:
- 0 - trias
 - 1 - quads
 - 2 - mixed
 - 3 - right trias
 - 4 - quads only
 - elem_size
 - The target element size.
 - connectivity
 - Manage the connection with input boundary/overlay elements. Valid values are:
- 0 - Generate mesh using given element size. Ignore elem_mark_id.
 - 1 - Manage connection with the user given boundary elements. Ignore elem_mark_id.
 - 2 - Manage connection with elements specified with elem_mark_id. Elements on elem_mark_id should be part of mark_id as well.
 - 3 - Manage connection with boundary elements which are not on elem_mark_id.
 - 4 - Manage connection with overlapped elements on elem_mark_id. Overlapped elements should not be tagged as boundary elements on mark_id.
 - 5 - Manage connection with boundary elements which do not overlap elem_mark_id elements. Overlapped elements should not be tagged as boundary elements on mark_id.
 - elem_mark_id
 - The ID of the mark containing the boundary/overlay elements used to manage the connectivity. Valid values are 1 and 2.
 - tol
 - The tolerance to use for overlay check. If set as 0, the tolerance will attempt to be automatically detected.
To create a section plane quad mesh of size 2.0, using elements 10-30 as boundary input, and elements 1-5 as overlapped:
*createmark elems 1 10-30
*createmark elems 2 1-5
*section_plane_mesh elems 1 1 2.0 4 2 0
   # Handle error
}Version History
11.0.130
