*ME_ModuleOccurrencesDeleteByMark
Deletes a mark of modules.
*ME_ModuleOccurrencesDeleteByMark mark_id
HyperMesh Tcl Modify Command
The module must be an occurrence and cannot be root.
mark_id
The ID of the mark containing the modules to delete. Valid values are 1 and 2.
Examples
To delete modules 1-10:
*createmark modules 1 1-10
*ME_ModuleOccurrencesDeleteByMark 1
   # Handle error
Version History
2019
