*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
Trims surfaces with lines and deletes the part of the surfaces enclosed by the lines.
*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 entity_type1 mark_id1 entity_type2 mark_id2
HyperMesh Tcl Modify Command
This command trims surfaces with lines and deletes the part of the surfaces enclosed by the lines.
entity_type1
Must be set to surfaces.
mark_id1
The mark ID containing the surfaces to trim. Valid values are 1 and 2.
entity_type2
Must be set to lines.
mark_id2
The mark ID containing the lines to use as the trimmer. Valid values are 1 and 2. The lines must form a closed loop.
To trim surface 16 with the closed lines with ID's 2, 3, and 4, and to delete the part of the surface enclosed by the lines:
*createmark surface 1 16
*createmark lines 1 2 3 4
*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 surfaces 1 lines 1
Version History
11.0.120
