*remove_fe_cracks
Stitches free edge loops in FE.
*remove_fe_cracks mark_id stitch_tol
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark containing the elements to stitch. Valid values are 1 and 2.
 - stitch_tol
 - The tolerance to use for stitching.
To stitch all displayed element cracks, using a tolerance of 0.1:
*createmark elems 1 displayed
*remove_fe_cracks 1 0.1
   # Handle error
}Version History
14.0
