*setqualitythresholdscolors
Sets the color for all element quality index ranges.
*setqualitythresholdscolors double_array number_of_doubles
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It sets the color for all element quality index ranges.
double_array
The ID of the double array containing the color values for each quality index range. Must always be set to 1.
There are currently 5 quality index ranges that can be set. The color for each range must be specified, using a value of 1-64. The order of the parameters is:
  • 0 - Ideal (ideal <= QI < good)
  • 1 - Good (good <= QI < warn)
  • 2 - Warn (warn <= QI < fail)
  • 3 - Fail (fail <= QI < worst)
  • 4 - Worst (worst <= QI)
number_of_doubles
Must currently be set to 5.
To assign the quality index thresholds colors: ideal 56 (green), good 41 (cyan), warn 28 (brown), fail 57 (yellow) and worst 3 (red):
*createdoublearray 5 56 41 28 57 3
*setqualitythresholdscolors 1 5
   # Handle error
Version History
12.0.110
