*elementtestfree1d
Tests 1D elements for free nodes.
*elementtestfree1d entity_type mark_id output_mark_id
HyperMesh Tcl Modify Command
- entity_type
 - The entity types to be returned. Both nodes and elements are supported.
 - mark_id
 - The mark ID containing the elements to test. Valid values are 1 and 2.
 - output_mark_id
 - The mark ID where the failed elements or nodes will be placed. Valid values are 1 and 2.
*createmark elems 1 "displayed"
*createmark elems 2
*elementtestfree1d elems 1 2*createmark elems 1 "displayed"
*createmark nodes 2
*elementtestfree1d nodes 1 2
   # Handle error
