*reviewentity
Graphically reviews a specified entity.
*reviewentity entity_type search_type id_name color string_array number_of_strings
HyperMesh Tcl Modify Command
This command graphically reviews a specified entity.
entity_type
The type of entity to review.
search_type
The method used to specify the entity. The entity is specified using the id_name argument. Valid values are:
"by name" - Entity is specified using the entity name.
"by id" - Entity is specified using the entity ID.
id_name
The ID or name of the entity, depending on search_type.
color
The color used to review the entity. Valid values are 1-64.
If specified as 0, the entity will be reviewed with its respective entity color (not yet available).
string_array
The ID of the string array that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
number_of_strings
Integer indicating the size (number of strings) in the string array created using *createstringarray. The valid strings are:
showcomps - This indicates that components in which elements/geometry are referred will also be reviewed. If not provided, only specified elements/geometry are reviewed.
Examples
To review component with ID 3 using color 10:
*reviewentity comps "by id" 3 10 1 0
To review element with ID 4, along with its component, using color 10:
*createstringarray 1 showcomps
*reviewentity comps "by id" 3 10 1 1
   # Handle error
Version History
11.0.130
