Extracts the midmesh of an input geometry.
        *midmesh_extract
        entity_type mark_id string_array number_of_strings
        HyperMesh Tcl Modify Command
      longDescription
            entity_type
          - The type of input geometry.  Valid values are solids, surfs, comps and elems.
            mark_id
          - The ID of the mark of input entities.  Valid values are 1 and 2.
            string_array
          - The ID of the string array that contains the additional optional input parameters. The
            string array is created using the *createstringarray command. This should always be set
            to 1.
          - Note: All parameters are case insensitive, and order insensitive. All parameters are
            optional, if not supplied, the mentioned defaults will be used.
          - Valid parameters and their syntax are:
                  CombineNonManifoldEdgesDistance=<value>
                - If two non-manifold/sharp edges are in proximity with another edge within the
                  distance given for this argument, they will be merged together at the
                  mid-location.
                  CombineNonManifoldEdgesFactor=<value>
                - Triggers the same option as CombineNonManifoldEdgesDistance,
                  but the distance is expressed as a factor of MinimumSize.
                - A value of 1.0 means the CombineNonManifoldEdgesDistance is
                  same as MinimumSize. A value of 0.5 means the
                    CombineNonManifoldEdgesDistance is half of
                    MinimumSize.
                - Default 0.5, range [0.0, 1.0].
                  DefeatureOpeningsFactor=<value>
                - Triggers the same option as DefeatureOpeningsWidth, but the
                - A value of 1.0 means DefeatureOpeningsWidth is same as
                    DefeatureOpeningsWidth is half of
                    MinimumSize.
                  DefeatureOpeningsWidth=<value>
                - If a hole/opening is of lesser width than the given value, it will be
                  closed.
                  DefeatureRibsWidth=<value>
                - If a rib's width is lesser than the given value, it will be removed.
                  DefeatureRibsWidthFactor=<value>
                - Triggers the same option as DefeatureRibsWidth, but the
                - A value of 1.0 means DefeatureRibsWidth is same as
                    MinimumSize.
                  DestinationComponent=<value>
                - Midmesh - All output mesh goes to Midmesh component or to the component whose
                  name is specified in the DestinationComponentName argument.
                  This is the default.
                - Midmesh.# - For each input geometry, the generated midmeshes are organized into
                  a new Midmesh.# component. # denotes a unique incremental number.
                - Original - For each input geometry, the generated midmesh is organized back into
                  the input components.
                - Original.# - For each input geometry, the generated midmeshes are organized into
                  new Orignal.# components.
                - Current - All generated midmeshes go to the current component.
                  DestinationComponentName=<name>
                - The prefix to be used for the new shell element components created for the
                  output mesh.  Default is Midmesh
                  ExtractionSize=<value>
                - The size at which the midmesh is extracted.  Default 2.0.
                  FlattenConnections=<value>
                - 0 - The default Y shaped connections are retained (default)
                - 1 - The output will be flattened at the connections. Y shaped connections are
                  flattened to T shape. Stepped geometry (One side continuous surface, and opposite
                  side steps) will be captured as continuous surface there by deviating from
                  middle.
                  IgnoreFlatEdges=<value>
                -  0 - No specific treatment done to remove flat bottom edges
                - 1 - Flat bottom edges are not retained in the output
                  MinimumSize=<value>
                - The value used for defeaturing the topology based on the factors
                  SupressProximityEdgesFactor, CombineNonManifoldEdgesFactor and
                  DefeatureOpeningsFactor. It is recommended to set this value the same as the
                  minimum allowable element length for your final target mesh. Default is
                    ExtractionSize.
                  StepOffsetMode=<value>
                - This option allows finer control of how stepped geometry (one side continuous
                  surface, and opposite side steps) is captured. This option is valid only when
                    FlattenConnections=1.  This option also deprecates
                    FlattenConnections=2.  For the sake of backwards
                  compatibility, if FlattenConnections=2 is defined,
                    StepOffsetMode is ignored.  Valid values are:
                - Automatic - Steps of different thickness across a common base surface are
                  automatically offset to a uniform distance from the base surface
                    (default).
MidEverywhere - Each step will be placed in the
                    middle.
MidThinnest - All steps that share a common base are moved to the
                    middle of the thinnest step.
MidThickest - All steps that share a common
                    base are moved to the middle of the thickest step.  This might place parts of
                    the midmesh outside the solid.
                  SuppressProximityEdgesDistance=<value>
                - If a manifold edge is in proximity with another edge within the distance given
                  for this argument, it will be suppressed. Sharp edges are not considered for this
                  operation.
                  SuppressProximityEdgesFactor=<value>
                - Triggers the same option as SuppressProximityEdgesDistance,
                - A value of 1.0 means the SuppressProximityEdgesDistance is
                    SuppressProximityEdgesDistance is half of
                    MinimumSize.
                  TargetElementSize=<value>
                - This value is used for fine tuning certain internal computations to go well with
                  the expectations according to the final target element size. It affects the
                  suppression of flat edges, and edges in proximity. Default is
                    ExtractionSize.
            number_of_strings
          - Integer indicating the size (number of strings) in the string array created using
            *createstringarray.
    Examples
      To extract the midmesh of all solids present in the model with element size as 2.0 with
        SuppressProximityEdgesFactor and CombineNonManifoldEdgesFactor as 0.5:
      *createmark solids 1 all
*createstringarray 3 {ElementSize: 2.0} {SuppressProximityEdgesFactor: 0.5} {CombineNonManifoldEdgesFactor: 0.5}
*midmesh_extract solids 1 1 3
      Incorrect usage results in a
Tcl error. To detect
        errors, you can use the
catch
        command:
   # Handle error
    Version History
        2019
        2020.1 - Added new options DefeatureRibsWidth,
          DefeatureRibsWidthFactor and StepOffsetMode.
        Deprecated FlattenConnections=2.
