*edgesuppress
Suppresses the selected edge.
*edgesuppress edge
HyperMesh Tcl Modify Command
- edge
 - The edge to suppress.
*edgesuppress(5)Only face edges which are interior to a surface or shared between two surfaces may be suppressed and unsuppressed. Suppressing an edge can combine two separate surfaces, and removes its affect on the mesh.
