*CE_MarkCombineLinks
Combine the individual/group links into a single group link.
*CE_MarkCombineLinks mark_id search_type search_rule update_state search_string_array search_number_of_strings ?keep_realized?
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark of connectors to combine. Valid values are 1 and 2.
 - search_type
 - The specific link type to search in the connector.
 - search_rule
 - The rule by which the link entity was added to the connector:
 - update_state
 - The update state of the links desired to be grouped:
 - search_string_array
 - A string array containing the list of of link IDs/names/UIDs need to be combined into a group, created using*createstringarray. This must be set to 1.
 - search_number_of_strings
 - Integer indicating the size (number of strings) in the search_string_array created using *createstringarray.
 - keep_realized
 - Option to keep the current connector state after the update operation:
Examples
To combine the component link IDs 1,2,3 and 4 of the connector IDs 2 and 5 into a group link:
*createmark connectors 1 2 5
*createstringarray 4 1 2 3 4
*CE_MarkCombineLinks 1 comps 1 2 4 0
   # Handle error
}Version History
2019
