*lineextendtoline
Extends line1 to line2.
*lineextendtoline line1 line2 capture_radius derivative direction
HyperMesh Tcl Modify Command
line1
The ID of the line to extend.
line2
The ID of the line to which line1 is extended.
capture_radius
If the point at the end of the extension is within the capture_radius of line2, then force the end point to be on line2.
derivative
1 - Extend the tangent to the line
2 - Extend following the curvature of the line
direction
1 - Extend the end of the line
-1 - Extend the beginning of the line
None.
