*attributeupdateintarray2delementmark
Updates one element of an attribute of type integer array.
*attributeupdateintarray2delementmark entity type mark identifier solver status behavior row col value
HyperMesh Tcl Modify Command
- entity type
 - The type of entity that owns the attribute.
 - mark
 - The number of the mark where the list of IDs resides.
 - identifier
 - The identifier of the attribute.
 - solver
 - The solver number of the attribute.
 - status
 - The status of the attribute.
 - behavior
 - The behavior of the attribute.
 - row
 - The row number the value to be changed resides in (first row is zero).
 - col
 - The column number the value to be changed resides in (first column is zero).
 - value
 - The new value of the 2D array element.
Examples
*createmark(materials, 1) 7 8
*attributeupdateintarray2delementmark(materials, 1, 1234, 1, 2, 0, 2, 1, 5)
