*visualizemode
Sets the parameters for visualization mode.
*visualizemode hiddenline fillmode meshmode plot
HyperMesh Tcl Modify Command
- hiddenline
 - Set to 1 for hidden line, 0 for wire frame.
 - fillmode
 - Set to -2 for contours, -1 for element color, or 0-15 for constant color.
 - meshmode
 - plot
 - Set to 1 to replot the screen after this command has executed, otherwise 0.
This command is valid only after the system has entered into visualization mode.
None.
