*hf_Create_DieCadSys
Creates a system from the CAD system stored in the database.
*hf_Create_DieCadSys reserved
HyperMesh Tcl Modify Command
This command creates a system from the CAD system stored in the database.
reserved
Reserved for future use. Must be set to 0.
To create a system from the CAD system stored in the database:
*hf_Create_DieCadSys 0
   # Handle error
Version History
11.0
