*removeposition
Removes a solver position from another solver position entity.
*removeposition mark_id1 mark_id2
HyperMesh Tcl Modify Command
Removes a solver position from another solver position entity. Currently only supported to remove positions with config 407 from positions with config 408 in PAM-CRASH Interface. Alternatively, *setvalue can be used.
mark_id1
The ID of the mark containing the position entities to which the positions in mark_id2 must be removed.
mark_id2
The ID of the mark containing the positions entities to be removed.
Examples
To remove all the positions with config 407 from all the positions with config 408:
*createmark positions 1 "by config" "407"
*createmark positions 2 "by config" "408"
*removeposition 2 1
   # Handle error
Version History
2021.1
