Fills gaps in FE from node lists selected on both sides of the gap.
      *fill_fe_gaps_nodelist
        list_id1 list_id2 max_width string_array number_of_strings
      HyperMesh Tcl Modify Command
          - list_id1
          - The list ID containing the nodes on the first boundary. Valid values are 1 and 2.
          - list_id2
          - The list ID containing the nodes on the second boundary. Valid values are 1 and 2.
          - max_width
          - Maximum allowed gap width to be filled.
          - string_array
          - The string array ID that contains the additional input parameters. The string array is
            created using the *createstringarray command. This should always be
            set to 1.
          - Strings are indicated using the format "name: value". Valid strings are:
                - AdjacentComp
                - 0 - Fill elements should be created in a new component.
                - 1 - Fill elements should be created in the adjacent component.
                - ByFeature
                - 0 - Features should not be considered.
                - 1 - Features should be considered.
                - CurvedFill
                - 0 - Gaps are filled without taking into consideration the shape of adjacent
                  elements.
                - 1 - Gaps are filled taking into consideration the shape of adjacent elements,
                  ensuring a smooth fill.
                - DefineMaxWidth
                - 0 - Ignore max_width for gap filling.
                - 1 - Consider max_width for gap filling.
                - DetectNodeClusters
                - 0 - The ordered input node list is used as-is for gap filling, without detecting
                  clusters in the input.
                - 1 - The ordered input node list is split and clustered based on connectivity.
                  This is useful for supplying multiple lists as input.
                - GuideNodePairs
                - Specifies an optional list of node IDs in the form "M1 M2 N1 N2 O1 O2 ..." where
                  (M1, M2), (N1, N2) and (O1, O2) are node pairs. These pairs are used to divide the
                  gap to be filled into smaller loops. When provided, gaps are filled ensuring that
                  the loops are split at the specified pairs. This aids in filling complex hole
                  shapes by guiding the filling process correctly.
                - Remesh
                - 0 - Fill elements should not be remeshed.
                - 1 - Fill elements should be remeshed.
          - number_of_strings
          - Integer indicating the size (number of strings) in the string array created using
              *createstringarray.
      To fill gaps less than 100 between node lists 1 and 2, including
        remeshing:
*createlist nodes 1 1 2 3 4 5
*createlist nodes 2 6 7 8 9 10
*createstringarray 2 "Remesh: 1" "DefineMaxWidth: 1"
*fill_fe_gaps_nodelist 1 2 100.0 1 2
      To fill multiple gaps, where the input list contains nodes from all gaps at
        once:
*createlist nodes 1 18 19 22 36 56 23 34 45 20 21 67 89 71 72 73 74 75 76
*createlist nodes 2 57 98 43 13 16 17 42 43 44 48 46 49 91 92 93 94 95 96
*createstringarray 2 "Remesh:0" "DefineMaxWidth:0" "DetectClusters:1"
*fill_fe_gaps_nodelist 1 2 0 1 2
      Incorrect usage results in a
Tcl error. To detect
        errors, you can use the
catch
        command:
   # Handle error
