*beamsectioncalculateresults
Calculates results for selected beam sections.
*beamsectioncalculateresults entity_type mark_id
HyperMesh Tcl Modify Command
This command invokes the beam solver to calculate the results for selected standard, shell, and solid beam sections.
- entity_type
 - Must be set to beamsects.
 - mark_id
 - The ID of the mark containing the beam sections. Valid values are 1 and 2.
Examples
*createmark beamsects 1 all
*beamsectioncalculateresults beamsects 1Version History
12.0.110
