*markprojecttoline
Projects entities to the line.
*markprojecttoline entities mark vector projectlinelist projectnodelist
HyperMesh Tcl Modify Command
entities
The type of entity contained on the mark.
mark
The ID of the mark.
vector
The vector along which the entities are projected.
projectlinelist
The ID of the list of lines to which the entities are projected.
projectnodelist
The ID of the list of nodes that are on the lines in the projectlinelist. The nodes are used to trim the line during projection.
None.
