*midsurface_show_for_edit
Displays all targets that are attached to the surface vertices and edges.
*midsurface_show_for_edit surface
HyperMesh Tcl Modify Command
surface
The ID of the surface whose vertex targets you wish to display.
To display the targets of a surface with ID 213:
*midsurface_show_for_edit 213
None.
