*createcollectorforpartiallycontained
Creates a collector and moves certain entities into the collector.
*createcollectorforpartiallycontained entity_type mark_id name config type reserved
HyperMesh Tcl Modify Command
- entity_type
 - Entity type to move into the collector. Valid values are:
- elems
 - loads
 - systs
 - vectors
 - mark_id
 - The mark ID containing the entities to move. Valid values are 1 and 2.
 - name
 - The new collector name. The collector type is determined by the entity_type.
 - config
 - Set to a valid config value to specify if only entities of that config should be moved. Otherwise, set to 0.
 - type
 - Set to a valid type value to specify if only entities of that type should be moved. Otherwise, set to 0.
 - reserved
 - Reserved for future use. Must be set to 0.
Examples
*createmark elems 1 1-100
*collectorcreateforpartiallycontained elems 1 comp2 0 0 0*createmark elems 1 1-100
*collectorcreateforpartiallycontained elems 1 comp2 104 0 0Errors
   # Handle error
}Version History
11.0.101
