*nodecleartempmark
Clears all of the nodes from the temporary node mark.
*nodecleartempmark
HyperMesh Tcl Modify Command
Clears all of the nodes from the temporary node mark. If a node is selected at the time this command is run, it will not be removed, but its graphic will be cleared.
None.
