*morphmaptonodelistvecoffset
Maps nodes to a line along a vector.
*morphmaptonodelistvecoffset entity_type_nodes mark_id_nodes entity_type_handles mark_id_handles node_list_id use_symmetry use_constraints project vector_id mode offset
HyperMesh Tcl Modify Command
Maps nodes to, or offset from, a specified line using the temporary shape created by *morphmaptshp and *morphmaptshpedge as a guide. Selected handles can optionally follow behind the morphing operation.
Nodes can be projected on to the line along a vector, normal to the line, or spaced evenly along the line (if the nodes belong to edge domains).
- entity_type_nodes
 - Must be set to nodes.
 - mark_id_nodes
 - The ID of the mark containing the input nodes. Valid values are 1 and 2.
 - entity_type_handles
 - Must be set to handles.
 - mark_id_handles
 - The ID of the mark containing the handles. Valid values are 1 and 2.
 - node_list_id
 - The ID of the list containing the target nodes. Valid values are 1 and 2.
 - use_symmetry
 - 0 - Do not use symmetry (only option)
 - use_constraints
 - 0 - Do not use constraints
 - project
 - 0 or 10 - Project along vector defined by vector_id
 - vector_id
 - The ID of vector created using *createvector for the projection direction. Must be set to 1.
 - mode
 - 0 - If *morphmaprecalc has been used to calculate new influences
 - offset
 - The distance to offset nodes from the target. Not used if project is 2.
To project nodes on mark 1 normal to a line with ID 23 with an offset of 1.2 when not using *morphmaprecalc:
*morphmaptonodelistvecoffset nodes 1 handles 1 23 0 1 1 1 1 1.2
   # Handle error
}Version History
2020.1
