*blocknodeupdate
Updates the finite difference nodes in a finite difference block.
*blocknodeupdate name function type start end number factor
HyperMesh Tcl Modify Command
- name
 - The name of the block.
 - function
 - 0 - add nodes to an index.
 - type
 - The index. Not used, if function is 2.
 - start
 - The starting position of the nodes to be added or removed. Not used, if function is 2.
 - end
 - The ending position of the nodes to be added or removed. Not used, if function is 2.
 - number
 - The number of nodes to add. Not used, if function is 1 or 2.
 - factor
 - The expansion factor. Not used, if function is 1 or 2.
Examples
*blocknodeupdate(block1,0,2,-10.0,110.0,50,1.0)
