*detach_solids
Separates solids that have shared boundary surfaces.
*detach_solids entity_type mark_id options
HyperMesh Tcl Modify Command
Separates solids that have shared boundary surfaces by duplicating the common surfaces and breaking, when possible, the connectivity between the edges and vertices of shared surfaces.
- entity_type
 - Input geometry type. Valid value is solids.
 - mark_id
 - The ID of the mark of input solids. Valid values are 1 and 2.
 - options
 - Defines the separation method. Valid values are:
- 0 - Selected solids are separated from those not selected. Shared boundary between selected solids is preserved.
 - 1 - Selected solids are separated from each other. Shared boundary between selected solid and those not selected is preserved.
 - 2 - Each selected solid is separated from all solids it has a shared boundary with.
 - 3 - Same as 0.
Examples
Assume that solids with IDs 1, 2, 3 have shared boundary surfaces between each other.
*createmark solids 1 1 2
*detach_solids solids 1 1*createmark solids 1 1 2
*detach_solids solids 1 0Errors
   # Handle error
}Version History
12.0.110
