*surfaceconefull
Creates a cone with a specified center and radius, and optionally, prepares it for immediate use in the automesher. It also can identify a conical region for the automesher to use under the mesh without surface option.
*surfaceconefull top center bottom center base radius top radius aspect ratio height
HyperMesh Tcl Modify Command
top center
A node specifying the top center of the cone.
bottom center
A node specifying the bottom center of the cone.
base radius
The radius of the bottom of the cone.
top radius
The radius of the top of the cone.
aspect ratio
A value less than 1.0 creates an elliptical cone or cylinder.
height
Height of the cone.
To create a circular cone with the top center at node 1, the bottom center at node 2, a base radius of 100, top radius of 0, and a radius of 50, but not create any elements:
*surfacemode (4)
*surfaceconefull(1,2,100.0,0.0,1.0,50.0)
If the top radius and base radius are equal, a cylinder is created.
The *surfacemode(4) directive tells HyperMesh not to pass the information on to the automesher for element creation.
None.
