*segmentsetaddfacesusingfacenumber
Adds faces of elements using a specific face number to a segment set.
*segmentsetaddfacesusingfacenumber name mark_id face_number reverse_normals element_id option
HyperMesh Tcl Modify Command
- name
 - The name of the segment set to update.
 - mark_id
 - The ID of the mark containing the elements to add. Valid values are 1 and 2.
 - face_number
 - The face number of the element (starting from 0).
 - reverse_normals
 - Create segment set:
 - element_id
 - If non-zero, specifies the single element to use instead of mark_id. option must be set non-zero.
 - option
 - If non-zero, specifies to use element_id instead of mark_id.
Examples
*createmark elems 1 1-100
*segmentsetaddfacesusingfacenumber "test" 1 1 0Errors
   # Handle error
}Version History
2020
