*elementtestinterangle
Tests 2 and 3 dimensional elements for whether or not they pass the interior angle element quality check, and puts those that fail on the specified outputmark.
*elementtestinterangle entities markmask testangle trias outputmark wantmin dimension contour title
HyperMesh Tcl Modify Command
- entities
 - The entity types to be checked. Currently, elements is the only allowable option.
 - markmask
 - The mark that contains the elements to test.
 - testangle
 - The value to use as a threshold beyond which elements should be considered to have failed the test (in degrees).
 - trias
 - A nonzero value indicates to test trias or tria faces, as opposed to quads or quad faces.
 - outputmark
 - The mark where HyperMesh should put the elements that fail the test.
 - wantmin
 - A nonzero value indicates to check if the element's smallest angle is less than the threshold, as opposed to its largest angle being greater than the threshold.
 - dimension
 - A code telling to measure the dimension of:
- 1 - Measure 1D elements.
 - 2 - Measure 2D elements.
 - 4 - Measure 3D elements.
 - contour
 - A code telling if HyperMesh should:
- 0 - Display the results of the test normally.
 - 1 - Display the elements color coded by their ratings.
 - 2 - Build a histogram showing the distribution of ratings.
 - title
 - The title to label the curve in the histogram.
*createmark(elements,1) "displayed"
*createmark(elements,2)
*elementtestinterangle(elements,1,135.0,0,2,0,2,0,"Quad Max Angle")
      The details of the interior angle element quality check can be found in the online help for the Check Elements panel.
