*hmmeshdrag
Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and one of the *drag...toformsurface commands.
*hmmeshdrag quads
HyperMesh Tcl Modify Command
- quads
 - If nonzero, specifies that the created elements should be quads.
To drag six nodes -100 units in the direction of the y-axis and create 50 elements without creating a surface:
*surfacemode 3
*createlist nodes 1 5 10 6 11 12 7
*createvector 1 0.0000 1.0000 0.0000
*dragnodestoformsurface 1 1 -100.0000
*set_meshedgeparams 0 5.0 0 0 0 0 0 0 0
*set_meshedgeparams 1 10.0 0 0 0 0 0 0 0
*set_meshedgeparams 2 5.0 0 0 0 0 0 0 0
*set_meshedgeparams 3 10.0 0 0 0 0 0 0 0
*hmmeshdrag 1
*storemeshtodatabase 0
*ameshclearsurface
None.
