*morphconstraintcreatesmooth
Creates a smooth type morphconstraint for the selected nodes.
*morphconstraintcreatesmooth nlist type closed name color
HyperMesh Tcl Modify Command
This command creates a smooth type morphconstraint for the selected nodes. During morphing, the perturbations of the nodes or dependent handles will be modified using a spline based approximation so that edge domains running along the selected entities will have smooth contours.
- nlist
 - The ID of the list containing the nodes. Valid values are 1 and 2.
 - type
 - 0 - Apply to nodes. All handles on the node list serve as anchors for the spline curve and nodes are adjusted to the curve based on influences
 - closed
 - 0 - Open ended
 - name
 - The name of the morph constraint.
 - color
 - The color of the constraint. Valid values are 1 through 64.
To create a smooth morphconstraint for nodes 1-5 with a closed loop:
*createlist nodes 1 1 2 3 4 5
*morphconstraintcreatesmooth 1 0 1 "smooth" 32
   # Handle error
