*groupcreatesameas
Creates a new group using an existing group’s dictionary/attribute data and type information.
*groupcreatesameas newname existingname color
HyperMesh Tcl Modify Command
- newname
 - The name of the group to be created.
 - existingname
 - The name of the group to copy dictionary/attribute information from.
 - color
 - The color of the group.
*groupcreatesameas("back","front",12)Main and secondary elements and/or other definition methods/information are not copied to the new group when you use this command. Only the attributes/dictionary information and the type information are copied.
