*addicconnectivity
Updates the connectivity of an IC element.
*addicconnectivity id inode_id dependency_array nrows ncols
HyperMesh Tcl Modify Command
- id
 - The ID of the IC element to update.
 - inode_id
 - The independent node ID.
 - dependency_array
 - The 2D integer array ID created by *createintarray2d. Each row contains a dependent node ID and its associated DOF.
 - nrows
 - The number of rows in dependency_array. Must always be set to 2.
 - ncols
 - The number of columns in dependency_array.
Examples
Create an IC element and update the independent node to 15, and dependent nodes to 16, 17, 18, and 19 with DOF’s 123, 345, 1234, and 123456:
*icelementcreate
*createintarray2d 2 4 16 17 18 19 123 345 1234 123456
*addicconnectivity 1 15 1 2 4
   # Handle error
}Version History
14.0
