*linedragelements
Creates a mesh by dragging elements along a line.
*linedragelements mark guide guideendpoints plane_id ondrag biasstyle biasing using_default_vector
HyperMesh Tcl Modify Command
- mark
 - The ID of the mark containing elements.
 - guide
 - The guide line.
 - guideendpoints
 - The ID of the list containing the nodes which will be used to segment the guide line.
 - plane_id
 - The orientation plane used to orient the line to the guide line.
 - ondrag
 - The number of elements to be created along the drag.
 - biasstyle
 - The type of biasing to use.
 - biasing
 - The biasing intensity value.
 - using_default_vector
 - 0 - Use plane normal vector
None.
