Specifies the mode for defining and using feature edges for element-based
    re-meshing.
      *setusefeatures
        mode
      HyperMesh Tcl Modify Command
      Specifies the mode for defining and using feature edges for element-based re-meshing.
          - mode
          - The mode for defining and using feature edges for element-based re-meshing.
          - 0 - Feature edges will be auto-detected using the simple feature detection algorithm
            (as in the Features panel). The feature angle is set using *setoption
              feature_angle.
          - 1 - The selected mark of 1D plot elements will be used to form feature edges. This is
            also useful for using the Features panel to detect and manually edit features. The
            elements are specified using *elementsaddelemsfixed.
          - 3 - Feature edges will be auto-detected by specifying the connected feature detection
            algorithm. The feature angle is set using *setoption feature_angle.
          - 7 - Use associated surface edges.
          - 8 - Feature edges will be auto-detected by specifying the connected feature detection
            algorithm, keeping 1D elements which are part of 2D mesh edges and existing FE edges
            with nodes already associated to surface edges.
          - 9 - Feature edges will be created from the selected mark of 1D plot elements, keeping
            1D elements which are part of 2D mesh edges and existing FE edges with nodes already
    Examples
      To remesh the displayed elements and keep lines formed by plot elements with IDs
        1600-2220:
      *createmark elems 1 "displayed"
*setusefeatures 1
*createmark elems 2 1600-2220
*elementsaddelemsfixed 2
*defaultremeshelems 1 3.0 2 2 0 1 1 1 0 0 0 0 0 30
      To remesh the displayed elements with auto detected feature edges with a feature angle of
        80 degrees:
*setusefeatures 0
*setoption feature_angle=80
*defaultremeshelems 1 3.0 2 2 1 1 1 1 0 0 0 0 2 30
    Version History
      9.0
      2020.1 - Added new mode values 8 and 9.
