*morphshapeapply
Applies the shapes on the mark to the model.
*morphshapeapply shtype shmark mult
HyperMesh Tcl Modify Command
- shtype
 - Shapes
 - shmark
 - Shape mark number.
 - mult
 - Multiplier to applied shapes.
*morphshapeapply (SHAPES,1,2.0)
      Shapes on the mark are applied to the model consecutively and scaled up or down by the multiplier.
For HyperMesh versions 8.0 and higher, active constraints will be applied to the shapes. For previous versions of HyperMesh, constraints were not applied.
None.
