*sketchdisassociateentities
Removes the association between the sketch and its realized entities.
*sketchdisassociateentities sketch_id
HyperMesh Tcl Modify Command
Removes the association between the sketch and its realized entities. If the sketch entity is hidden, it becomes visible.
- sketch_id
 - The ID of the sketch entity.
Examples
*sketchdisassociateentities 1Errors
   # Handle error
}Version History
2021.2
